Daytime running lights module for a 99
SILVER BLUE 99
Windsor, ON Canada
I'm hoping someone can help me find a DRL module for my 99.
Daytime lights started flickering and eventually went out. Seems intermittent though. Fuses look good as well as bulbs so I think it's the DRL module or possibly a bad wire connection?
I've looked online and contacted dealers along with Dorman which used to make a replacement part. Unfortunately no luck so far.
I have attached the part number along with a picture of the actual module.
Any help is appreciated.
Viper514
Canada
Just picked one up at a junkyard out of a 1995 dodge neon. ill let you know if it works.
Viper514
Canada
Worked. Runs off the high beams.
SILVER BLUE 99
Windsor, ON Canada
I ended finding a used one from an Intrepid.
Looks identical. Bolted right in but seems to work TOO good. Lights won't turn off. E-brake has no effect nor does turning the car off.
Safe to assume this module is no good either?
If anyone has one that's tested and willing to sell/ship, please let me know.
