DETAIL question
V10 MOJO
Youngstown, Ohio
regarding polishing, allegedly the more applications you do, the deeper the shine and wet look, how long to wait in between? will using misted water in between help
Matt M PA
Langhorne, PA USA
Depending on the actual polish you use, more coats will not always "build up". Zaino will build up and to avoid the waiting time, they now have the ZFX accelerator. I just got mine but have yet to try it. If it is typical of Zaino products..it will do exactly what they say it will.
PETSN8K
memphis, tn
It all depends on which product you use. Some require longer to "cure" than others. Zaino polishes take between 6 to 24 hrs to cure without the use of their new additive called ZFX which significantly reduces the curing time (it does work by the way). Other products like Blackfire and Klasse require little to no time between coats. All of these polishes can be layered without the yellowing, streaking or hazing associated with multiple coats of a cheap wax. And the collective effect of the additional coats really does improve the shine. As for using a spray in between applications, I have found this is useful only because it helps remove any excess polish left over after buffing. Therefore it actually increases the shine and reflective qualities of the finish. I know Sal has other reasons for using his Z6 in between applications but I think he will admit this is one of the major reasons. Anyway I hope this answers your questions.
Yaccob2
