only when you get belt slippage, you will hear the owner whining.
Not sure which ones you heard but the Paxtons make noise at idle. Put on a smaller pulley and spin the supercharger faster at idle and it will make more noise.
Maybe you heard the Roe? Roe's are quiet until you spin them and then they sound like a screaming banshee
420 you sound like a broken record here..we have answered your questions...about the noise maker...it's going to make noise with any pulley.
2manytoys...if you have the paxton kit...and you are running the 2.75" pulley which I am sure you are...plus running a 8 rib system...don't kid yourself..you are getting belt slippage. DLM pulley system is way superior than your Paxton kit pulley since he uses multiple pulley system...plus runs a 10 rib... Also even if you had the Paxton kit pulley replaced with a stronger tensioner pulley...you are still getting some belt slippage. There's tons of stuff on that paxton kit that is not made to be durable for High HP applications.... yeah you can get high HP out of it...but wait and see what the weak links are. I am fabercating a 10 rib system for myself and also multi pulley system.
Anyone with a centrifrugal set is is going to get some belt slippage period! I gaurantee if I looked at your system, I would find plenty of black dust.
Touchy! Touchy!Touchy!
I don't pat myself on the back...and no I don't have a Paxton Kit on my car..not even close. You running air to air or is it air to water? Using the paxton kit bracket to hold your system up? Well if you are...I would say you have a modified paxton kit.
You know what I pat myself on the back for...not having to send my car off and doing it myself. Knowing alot about my system and if something does go wrong knowing where to look and fixing it myself...having many people ask what I did and looking to me for advice...then yeah..maybe I will pat myself on the back... Do you get that a lot or do you handout website and phone numbers? I seriously don't care if you don't know a spark plug from a steering wheel....or if you used a tuner or not..so fricking what... Good for you that you have a fast Viper. I will have my turn on the track soon and will be putting down some good numbers..if I beat you or if I don't...I really don't care....I built my car for reliability...and for me...not so I can have a sig that say's "blah..blah...blah..." Stop taking offense to all this stuff.
