Door handle push button on GTS.
Jance GTS
Oklahoma City, Oklahoma
How much does your door open when you push the button on your GTS without grabbing the handle? Is the door suppose to barely open so you can grab the handle to open it or does it push the door open a few inches?
Also what actually opens the door? Is there a popper or is it an actuator?
Thanks!
vancouver-gts
Vancouver BC
Don't think the door should pop open on its own at all without pulling on it by the handle while pressing on the button.Have to check it when I get home tonight.
J
Jance GTS
Thanks for checking. Mine does the same. I just wanted to check to see if it was how they were designed or if they are just getting weaker with time. Good to know! :)
