All Blue ACR
So I'm farting around and removing the side sill plates that were on my car when I bought it. As I work I'm opening and closing the driver's door a lot but only allowing the door to rest against the latch (but not clasped) each time I go for more tools.
I come back and the door is partially latched and the door popper won't work so I go around to the other side, no go there either. I force the drivers door completely latched, still no go. Luckily the keys were on my bench so I hit the lock/ unlock on the fob numerous times, horns and lights work, still no go. Open the hatch glass and open the door manually. Open and close it manually a dozen times;still no door popper, start the car, no go. Check the fuses, OK. Won't open from inside with the regular latch either; only the emerg. one
Finally I go inside to look for my manual and as I'm walking in I hit the lock button a bunch of times honking the horn cause I'm pissed. Come back with the manual and they unlock and work
What did I do and how did I fix it??
