doors will not unlock, Help!
Gavin
Monterey, Ca, USA
Lift the hood
Disconnect the + battery cable
When you disconnect the + cable you should hear the doors unlock-leave disconnected for a couple of minutes.
I believe you should remove the battery to charge it
Re-install
Then start the car
I am pretty sure you cannot jump it to start it.
onerareviper
Pittsburgh, PA, USA
Easy....
Open the rear hatch with the key. Reach your arm around, and pull down the emergency door release. Had to do it once myself...
Later
ViperGear
