Drag suspension for the viper
varanus
pleasanton,ca 94566
I second that. Albert has always gotten parts to me on a timely basis and has spent time discusssing things that i needed info on. Thanks Albert.
PS
What are these drag shocks they are talking about?
jp
Umea, Sweden.
I use Eibach springs and the stock Konis rebuilt to Koni SPA-1 specifickations, works Great!!! My 60 footers are 1.51 to 1.54!
/JP
Springs: 500 USD
Rebuild of Konis to SPA-1 specs: 500 USD
9 seconds
Texas
I think suspension is what keeps most 725-750 rwhp Vipers from dropping into the single digits. I had TNT put adjustable shocks on the front of mine. They believe I could go faster if I lowered the rear. Having the shocks is only part of the answer. Knowing what shock settings to use and the correct spring adjustments will get you where you want to be. That's probably 1.47 or less 60' times for 9's.
oldvenom
