draining the 1998 gen II coolant
Qualitywires.com
Louisville, KY
I've done my 1994 rt/10 coolant system but was wondering if it's the same as doing the 1998 Gen II engine?
Any recommendation on a good coolant to use?
Thanks in advance.
Joel
Ireland
I think the expansion tank set up is different, try a search, I think its been covered several times, I used Bluecol protek which has trigard corrosion protection at a 50:50 ratio. It also has I think a 5 year lifespan. May not be available in the states.
osssx
