OBD2 scanner
mhpearlman
2014 GTS with 6k miles (what I feel to be in perfect condition) and the check engine light just came on. Any suggestions for a scanner made for a viper? or all scanners built the same? thanks
I would suggest that you get an inexpensive scan tool from Harbor Freight, Northern Tool, etc. Just be sure that is OBD II, CAN bus, reads and clears codes. They are $40.00 to $60.00.
I carry one in all cars...note just to clear the codes, but by doing so, one can get the car out of limp mode (at least on a temporary basis).
Remember: clearing codes is not a cure for the issue. Always record any codes that you plan to clear.
Dave1968
I say spend a few bucks, get a good one as it will show you a lot more. Autel makes great units. You will have it for life and can use it on any vehicle with the OBD2 port. Have Fun!
RandyM
Seabrook, Texas
I suggest when you look for one, get one that will also diagnose ABS systems, some of the less expensive ones will not.
InTheZoneAC
obdlink mx+, wireless unit. Also supports other apps besides their own if you want to use another app.
I have a Xtool D9 and its Bidirectional. I love the Bidirectional feature. Does pretty much everything under the Sun including OBD I.
Comes with 3 years of free updates as well.
Transel
