Gen 1 Differential Fluid Change
jkroberts21
Alpine CA
Progressing with changing all the fluids but when I got to the differential, according to the service manual's directions, I attempted to withdraw the fluid with a suction tool, but the fluid seemed way too thick to **** out. I did let the car sit for a few hours after driving it, but the 75w-140 amsoil I bought to replace the fluid was way thinner
There appears to be a drain plug in the bottom of the diff. Can the fluid be drained that way?
Can anyone who's changed the differential fluid in a gen 1 give me some advice on procedure?
Much appreciated in advance
steve e
A bit of advice, before you drain any transmission, differential, transfer case, make sure you loosen the fill plug first, I can't tell you how many cars have been towed into my shop because the owner couldn't loosen the fill plug after he drained it, they can be over tightened and a bear for the home mechanic to get loose.
maverickagm
New Westminster
Does anyone know the drain plug socket size? A 1 inch box-end wrench feels a tad loose. I suspect it might be 25mm (1 inch = 25.4mm).
Also, I second checking the fill plug first! I had to use a 3/8" hex socket on a breaker bar. Don't attempt to use any other socket that has even a little bit of wiggle.
maverickagm
New Westminster
Update: I suspect it is a 3/4-16 UNF plug, otherwise known as an 8AN ORB (o-ring boss) plug. I'll post back once I get a hold of one.
A 1 inch socket is required. Does anyone know what type of pipe plug this is?
Mine is missing the o-ring and I deformed it a bit when removing it. The threads look parallel instead of tapered and the pipe plus is made of aluminum.
eman319
