Gen 1 Differential Fluid Change
jkroberts21
Alpine CA
Progressing with changing all the fluids but when I got to the differential, according to the service manual's directions, I attempted to withdraw the fluid with a suction tool, but the fluid seemed way too thick to **** out. I did let the car sit for a few hours after driving it, but the 75w-140 amsoil I bought to replace the fluid was way thinner
There appears to be a drain plug in the bottom of the diff. Can the fluid be drained that way?
Can anyone who's changed the differential fluid in a gen 1 give me some advice on procedure?
Much appreciated in advance
steve e
A bit of advice, before you drain any transmission, differential, transfer case, make sure you loosen the fill plug first, I can't tell you how many cars have been towed into my shop because the owner couldn't loosen the fill plug after he drained it, they can be over tightened and a bear for the home mechanic to get loose.
