Bruce H.
For those that have tracked theirs on the street tire...do they hold up fairly well to track temps without significant chunking, excessive wear, etc? I would think the TA's extra camber would help, nor would I be pushing the car that hard as I will need to drive it home again I should have it on the road early April, 1 or 2 local HPDE to learn the car in May, and then a 3000+ mile road trip in June with 2 track days at both Road Atlanta and then Virginia International. One set of tires needs to go the distance, and I'm sure to run into wet weather driving on road and possibly track where the street tire could be the safer bet. It also seems senseless to wear out a set of Corsas around an HPDE skidpad/track while learning the car, and with endless highway use. If that's the tire I need I could also get the dealer to swap the tires when he gets the car next month before I take delivery so the R-compound Corsas won't be subjected to below freezing temps (my garage isn't heated).
Also, I'm sure to need to change pads after 2 days at Road Atlanta, so I'll need to take spares and tools with me to do that. Which pads have you track rats tried, what's do you recommend based on first hand experience for a car that will see equal street and track use, and is changing the pads a fairly straight forward job on a Viper? I don't expect to want to push the TA too ******* the track, like I have other track cars, so the pad selection can account for that. Then again, I seem to always end up threshold braking!
Thanks in advance,
Bruce
Thanks in advance,
Bruce
