Dry sump or not to dry sump
luc
Paso Robles CA
You don't need a dry sump system on the street.
There are 3 reasons to run a dry sump on a race car.
1/ oil pressure.
Many cars oil pick-up system are not designed to deal with a lot more than 1G and consequently you can loose oil pressure in turns and get air in the oil.
2/ Horsepower.
On a dry sump the oil pan doesn't hold any oil and there is no chance of the connecting rods of hitting the oil and foam it.
Also with a dry sump, the crankase pressure is negative and you can use "looser" rings.
3/Cooling.
a lot of BTU's are removed through the pump,hoses and tank.
I will realy doubt that you feel the difference in HP, at the most you will get 10HP without changing the rings.
$1800 is cheap.
A 4 stage pump,usually 3 scavenging and 1 pressure, is over $1000.
AN fittings and hoses will run at least $500 and a oil tank between $300 to $600 depending on size,design and brand.
Luc.
