E-brake adjustment
johnk
Laplata, Maryland
What's the procedure for adjusting the E-brake, I have too much travel in the handle. Pads look fine. Thanks
Roadrunner
It is supposed to be self adjusting... crank on it pretty hard, a little further than you might think, and it should ratchet another notch if it is rising too high for you.
The mechanism can be seen under the center trim panel... it can be "pryed" (don't pry, use a trim stick) up and you can see the works at that point. carefully unplug the window switches to get better clearance.
Luigi93
