Open the hood and remove the washer fluid reservoir.
Use a 2 1/2" hole saw to drill an access hole.
Now you have access to the "E" clip and basket clip.
Pop off the basket clip to release the master cylinder shaft.
Slid off the "E" clip without loosing it.
Now you can remove the pedal off the shaft from inside the car. Clean it, lube it, and put on the new nylon bushing.
Install the pedal back on the shaft fron inside and put the clips back on from the access hole.
Install a 2 1/2" body plug ($2.50) in the hole.
Re-install the washer bottle.
