There have been plenty of threads on this but, as you have come to expect (I Hope
) from me... I wanted to let you all know what I did and give you some photos of the job and the before and after. Like the other mods I have done so far, none of this is rocket science, but I feel that I have gotten some good shots that sometimes the other threads fall short on. Also, I tried my best to give you before and after shots in similar positions so that you can get as good a before and after as I could give you. I may be getting worse with the search engines with age, but I could not seem to find a true before and after of this change. I hope mine helps.
Again, not rocket science, so I am not going to go into huge detail, but I will mention some things to help those that are thinking about the mod. It really is quite simple but just requires some thought, the right tools and a bit of muscle or leverage (depending on how you look at it
). You can do this one corner at a time but, as you'll see in a bit, if you need to get all four off at once, you'll have to lift the car and place it on stands. I put in a few shots of that just to give folks an idea of what I do to get it up on jack stands. Where I locate them, etc. So here goes.
I have the benefit of two floor jacks. As a result I lift the front and rear with two jacks at a time. This way, i lift it evenly and I don't tweak anything. I lift the front first then the rear. Once it's up on the four jackstands, I put the floor jacks at the front lift points and just pin them in place. They are just there as safety/backup and to give it more "left to right" stability.
Here is were I place the front and rear jack stands.
Since the car is on coil overs (although fixed) replacing the springs is basically just a matter of getting the shocks off and then swapping out the springs. To get the coil overs out requires the removal of two bolts per corner. If you want to make life a bit easier, on the fronts, you can remove the sway bar links from the lower control arm. This allows for easier removal of the lower shock bolt. I did that. What I discovered in the process is that the boots don't last 10 years. The links are perfect on the sway bar tie rods, but the boots are damaged. I'll upgrade/change those later. For the sake on completeness, I've included a shot of the four bolts, two for the front and the two rear. However, it's obvious when you look in there.
Front top and bottom bolts.
The rear top and bottom bolts. Yes, this is after they have been replaced. Those are the new springs.
I'll continue on the next post.....
![rolaugh :rolaugh: :rolaugh:](/vca/styles/default/xenforo/smilies/rolaugh.gif)
