Eibach springs which ones go on the front????
96 B&W GTS
Miami
I just installed Eibach springs in my 96 gts. I installed the pair with the tighter coils in the front because I assumed that their is more weight in front. Is that correct??????? The car looks lower in the rear but the front looks the same? I hope I did not just do something really stupid!!!!
BDZ1984
Frisco, Texas
Is it just me or are the rear springs wider than the front??? I do agree Eibach should put some sort of label on them...
Turbo50Mike
North Jersey
Yes, but only by about .200", so if you don't measure, or don't know where the springs go, you end up mixing things up a little bit.
At least it was good practice, now you'll be a pro at changing springs!
Polak
