motor602
alright guys and gals quick question, was curious if the electrical problems im seeing are related to something bigger or are just isolated incidents. About last year my high beams won't stay on when engaged, they just act as if you were flashing them, not turning them on. Additionally my cockpit lamps on the rearview turn on when the doors open, however when the doors are closed they cannot be turned on with the actual switches on the rearview. Finally im havin trouble with the drivers door, specifically the door handle sometimes does not work when the door is closed, and when the door is opened to its extreme angle the speaker cuts out. I feel this last issue may be due to the wiring harness in the door jam being crimped and losing connection, however just wanted to throw this stuff out to all of you. Again, is there a common electrical problem or do these sound like isolated problems that need fixing.
