craig_g
I have a 1999 rt-10. my drivers side exhaust cover is starting to turn brown from alot of heat. The passanger side does not seem to be having the same problem. I have stock headers with a B&B cat back system. I purchased the car as is and had the side covers repainted due to this. while the covers were at the shop I wrapped the mufflers with heater wrap to help provent this from happening again. no such luck !!
so,,,,, do you guys think I should just get a cat delete kit and be done with this problem ? I belive the left side cat maybe going bad and causing the excess heat. I have not had a check eng light come on, I thought that maybe if the cat weas going bad it would throw a code but nothing
