ViperDEN_Nick
- Joined
- Jul 13, 2016
- Posts
- 42
- Reaction score
- 1
Hey guys,
Did a search and most, if not all, the threads are a few years old. As the title states, failed emissions today in CO. They do both the "Sniff" and OBD.
The OBD test shows no trouble codes. The CEL test passed, and was not illuminated.
I've had the car less than a week. 1996 GTS. To my knowledge, it has a Mopar Cat-Back Exhaust, Cam and assuming a tune came with it. These are the only mods that would effect the emissions.
The readings came out:
- HC: Read, 4.59...Limit, 1.2
- CO: Read, 19.60...Limit, 15
- CO2: Read, 581...No Limt
- NOx: Read, 3.60...Limit, 2
The stock Cats are still installed. I'm not sure on the integrity of the O2 Sensors (thinking about putting on new ones). The reading I've done on failed emissions tests, these numbers indicate that the car is running on the rich side. I can see that since the car originated in GA/FL area and is now up at a higher elevation in Denver.
Aside from potentially swapping the O2 Sensors, I'm thinking about unhooking the battery to try and reset the PCM to the higher elevation and try the test again. Any other suggestions that may not break the bank?
Thanks!
Thanks!
