Matt M PA
I did a search...but what I'm finding isn't making sense.
When my 2000 was new, the hood-fascia gap behind the headlights directly in front of the wheels was the same on both sides. Now, the driver's side is substantially wider...in fact the double the distance on the passenger side.
The gap above the headlights to the hood is almost even from side to side, and the fit to the fascia between the headlights is fine. The fascia has never been removed.
The ends of the fascia are held by a handful of small bolts that go into rivinuts in what the parts book refers to as a "radiator close-out". (On the passenger side, the close-out has the window for the coolant tank)
I've read that the rod inside the fascia needs adjustment to move the ends of the fascia. However, it is connected to the close-out...so I'm assuming the entire close-out needs to be adjusted/rotated?
I'd sure appreciate some thoughts...I seem to only need to move the driver's side of the fascia up.
