Stock cam
Kn intake
Custom Titanium exhaust (deleted catalyst converter set #1 on the exhaust)
Roller rockers
Findanza lightweight flywheel
Lightweight underdrive pulley
Abs wires
170 degree thermostat
Baush plugs
Sct tune
=475/512 sae, 487/522 std
Bsm dynojet
Only the following modifications were made
710 cam
Beehive springs to support higher lift cam
Forged pushrods to support higher lift cam
Gen4 head gaskets (slightly thinner raising compression from 9.6 to 9.8)
New sct tune to support 710 cam
Deleted catalyst converter set #2 after the headers
=543/546 sae, 556/559 std
Bsm dynojet
Car drives like a stock 03 Viper, Cant stress that enough. Just sounds awesome and pulls like a freight train with my weight reduction at 3250 pounds
I GAINED 68 RWHP SAE!
THERE WILL UNDOUBTEDLY BE NAY SAYERS WHO TELL YOU ITS BECAUSE OF MY GEN4 HEAD GASKETS OR DELETED CATS. WELL I HAD THE SAME GEN4 HEAD GASKETS WITH MY COMPETITION COUPE CAMSHAFT AND THAT SETUP ONLY HIT 486/530 SAE AND 499/545 STD. SO THAT THEORY GOES OUT OF THE WATER. THE DELETED #1 SET OF CATS ARE GOOD FOR 5-10 RWHP TOPS.
In short. The RoeRacing camshaft is good for 50-60 rwhp (60-70 crank hp) over the stock cam. I wouldnt belieave it unless it happened to me.
Stay tuned for quartermile passes
Kn intake
Roller rockers
Abs wires
Baush plugs
Sct tune
Bsm dynojet
710 cam
Bsm dynojet
