For those who have installed a DLM Intercooler and pump.....
johnk
Laplata, Maryland
I installed the DLM intercooler pump first, then went to install the intercooler. 3 questions, 1) does the hose that normally goes to the driver's side of the stock Paxton intercooler go on the bottom 45* ****** of the DLM intercooler (but hose needs to be significantly shortened)? Is that lower 45* ****** the inlet for the intercooler? b) what's the trick to get it on? I suspect I need to take the discharge hose off the pump, mount it to the intercooler first, then mount to the pump. 3) does the intercooler just hang directly below the cross bar and attach with a few tie wraps? I'd like to get this thing wrapped up tonight or I'd just wait to call Doug in the AM.
J
johnk
Laplata, Maryland
I spoke with Doug today, he goes out of his way to help. The line from the pump goes to the lower (45*) ******. As that hose approaches the intercooler pretty low on my car, I purchased a section of hose with a 90* angle, attached it to the intercooler so the free end of the hose ends up pointing down, then slid the unit in place while guiding the hose through the cutout in the side panel.
Hiss
Kentucky
Doug is very helpful.
I think you will like the cooler and pump. Let us know.
Luigi93
