Found the frame VIN
GTSHolgi
Germany - Rheinland
For those of you who were looking for the frame VIN without success (like myself until today ;-)): You can see the VIN stamped in the upper right frame rail if you look between the radiator and the right head light (passenger side). There you can see the upper frame rail and if it's not too dirty you should be able to see and determine the VIN. I tried to make a picture but it didn't work as there is not much room and my camera just refused to work under these conditions....but you should be able to find it.
Holger
G
GTSHolgi
Germany - Rheinland
Now, I could also locate and find the VIN stamped in on the engine block as also described by the International Viper Registry. It wasn't easy but with a small pocket lamp it was possible to manoeuver the light to that area on the rear side of the enginge block (standing next to the car on the passenger side close to the cowl). I think, you will never be able to find/see it having the car on a lift and looking at the undercarriage (which was my first thought).
Holger
FirecatF7
