Since I want to have it painted, I was thinking it would be a lot less expensive than having the body shop tape off the rest of the car.
They should want to paint it off the car, black is usually a good match.
Remove the front wheels
Remove the front upper part of the wheel well
Unplug the fog lights
Remove the double 10mm and bracket (fender to bumper)
Remove the 8mm bolts at the bottom of the bumper
Remove the 8mm bolts in the middle of the bumper (4)
Remove the 8mm bolts at the top of the bumper
With two people stand on each side of the bumper and pull the bumper over the lower part of the wheel well.
Done.
Be very cearful when putting it back on or the part you pulled the bumper over will mark the new paint.
