topsnake
I drove 40 miles yesterday to check, if everything works in my car. I had to switch the engine and many parts, that have been mis-modified by someone. Also the current PCM makes the air/fuel ratio much too rich. I have a heavy smell of fuel in the 40 mile old oil and have less power.
In stock mode, my 2000 PCM worked with two O2 sensors (both upstream) and nothing else (export model). Currently, a 96 PCM with more power is installed, but this one needs 4 O2 sensors. I only have two ones in the car.
My stock PCM is also broken by the guy, so I can't use it anymore. A new one costs over 1500 EUR in Germany.
I have no catalytics anymore, so I can't use 4 O2s. What should I do? How good are the simulators from Roe?
How do they work? Does the signal voltage vary or is it a static signal feed?
Would a Vec2/3 fix this problem? Is the fuel ratio adjustable here? Without caring about the O2sensor voltages?
In hope, my current engine has got no damage yet..
Dennis
I want to ride again!
YouTube - b27
Dennis
YouTube - b27
