Fuel Injector Cleaner?
Tom F&L GoR
Wappingers Falls
Look for a bottle that says "complete fuel system cleaner" or similar rather than just "fuel injector cleaner." The active material is often the same, whether it's Techron or something else, but you get a higher dose in the "complete fuel system cleaner."
Detergent performance can be simplified by how far downstream the hardware is. A little bit of detergent will clean carburetors, more detergent will clean intake ports, even more will clean valves, and the higest amount will often also clean combustion chambers and piston tops.
Aftermarket treatments that sound passive (i.e. the product "cleans" rather than "cleans up" or "removes" deposits are often just a maintenance dose; something that adds only a little detergent and for adequate cleanliness, should be used every tank. The economics for these products are ... good for the marketer.
Some of this stuff gets in the oil. If you use aftermarket products, try to plan to use it a tank or two before an oil change.
J
Jeff Torrey
Plaistow, NH USA
What I bought was STP super concentrated Fuel Injector Cleaner.
One treatment claims to; Unclog Dirty Injectors, Restore Lost Power, Improve Engine Performance, Eliminate Tough Starts.
Last year I had a some problem with bad gas. Just using it as a preventive thing.
Thanks for the info!
Viper Wizard
South Salem, NY USA
Mapar sells a "Fuel Injector Cleaner" Part #4318007.
CONTENTS: Kerosene,Xylenes,Polyamides,Ethylbenzene,Naphtha,Heavy Aromatic. [Kept out of reach of children!]
I know it works on the "Around Town Cars" [From home to the store]. I have used it for years. It hasn't hurt anything thing yet.
What do you all think of it??
FirecatF7
