Jack, are you running two or three? Apologies if you already stated this.
If you are running three, where did you get a 3-1 Y block for the pump feed lines?
I am currently running a single 255 with a BAP. I have some issues with a drop on one fuel rail. I want to try and fix it with a more even distribution first. If that fails I want to quickly jump into the twin pump set up. I do have a a 3:1 adapter. If you want to use three pumps I would go three into the adapter and come out with two, one to each rail.
