Gas Pedal re-position?
eliems
Vancouver BC
My gas pedal is too close and my leg is bent too much operating it. My son with his longer legs couldn't stand it!
This picture shows the lower control arm being operated by the arm with the pedal. Is it possible to adjust this or hook the pedal directly to the lower control arm?
Have any of you adjusted your pedal position? How?
V
Venomiss
Guest
You have adjusted it with the electric switch under the steering wheel?
If it's older it's a turn knob under it.
E
eliems
Vancouver BC
Wow! Thanks, I really need to get me one of those whatcha ma call its? OWNER"S MANUAL. :rolleyes:
AZTVR
Chandler AZ
Take a look and see if the owner's manual might be in the pocket on the backside of the passenger or driver's seat.
Kala
Ojai, CA
It looks like he is already down at the carpet...
Some guys use the seat lowering kit to change the angle a bit... Might help?
E
eliems
Vancouver BC
I adjusted the knob mentioned above and the Gas and Clutch moved substantially back to give me all the room I want. In fact I think I will bring them back a bit!
Cool! :clap2:
FirecatF7
