The Roar In The Night
Hey all,
Told ya I'd have questions - time to begin!
This relates to the shifter. The 2001 RT/10 I recently acquired has (documentation claimed) a short throw shifter. I am finding a couple of issues with the shifter, I'll try and describe them all below so someone can tell me what is up (which may just be me)
1. There is not the merest hint of a "spring to center" horizontally, if I move it to the 1st to 2nd axis, it will just stay there, for example. I find this makes it tricky especially on downshifts from 5th say, as I can't tell if I'm going to hit 4th or 2nd (which would be ugly.) So far, I have to pull it all the way left and then move right to make sure I'm not hitting the low 2 gears.
2. Horizontal movement is pretty stiff, and moves in notches. I don't mind the notches so much, but should the horizontal movement be stiff? I'd say it's close to actually putting it into a gear to move along the horizontal axis.
3. Sometimes in coming out of a gear, I have no horizontal movement at all. Most noticeable for me coming out of 5th (downshifts are where the majority of the issues lie for me, other than occasionally going into 5th rather than 3rd which is non-problematic as I'm not doing anything dramatic in the car just yet and is just disappointing in the engine-noise department.)
Of course, the question of stiffness and hardness is relative (said the actress to the bishop) so any of the above may just be me and my inexperience with Vipers, and / or this type of gear shift. I've been browsing and reading and searching, and I see there are possible things that could be causing it that are more than just me - e.g. could be the transmission fluid (since it's bought used, don't know when that was last changed), the type of shifter (it may not even be a short throw, may just be a short stick put on the stock, and I hear the stock can be pretty unpleasant), or some sort of fault or problem developing in the shifter.
I'd welcome folks feedback on what thoughts come to mind from what I've described.
PS - I'm not very mechanically inclined (flame suit on) though I am sure I'll be getting more so over time of ownership
Right now I'm not even sure how to get the shifter cover off safely to find out what the shifter looks like under there without tearing something up so that I can identify just what IS installed, tips on that welcome also, searches didn't show anything on such a basic step during guides on changing out shifters.
