Gen 1 Photo Needed
KNG SNKE
Portsmouth, Rhode Island
Can one of you Gen 1 owners please post a couple photos of the underside of your rear bumper and its mounting points? Also is your rear bumper soft like the Gen 2's, urethane? Etc? Thank you in advance.
jdeft1
Metropolis
I wonder a bit where you're going with this. Swapping a bumper? The gen 1 bumper cover is soft plastic and wraps way back underneath... similar to gen 2 but with no exhaust through the middle. I've never had a reason to get to the actual bumper mounting points on mine so certainly don't have any pics. I do have a body/frame book for gen 1 that may show what you're looking for if you can't find the pics you want. Hopefully somebody will chime in with some images.
K
KNG SNKE
I need a photo where the bumper cover bolts. No need to jack up the car, just put the camera low and snap a photo.
I have another thread where I made diffuser blades for gen 2's and I have a gen 1 guy interested in them though I don't know how the gen 1 bumper cover is bolted down or if its even bolts or rivets.
jdeft1
Metropolis
Check..
If none are posted by the time I get home from work, I'll go out a snap a few for you.
Texas1
40 acres & a mule...
I read your other thread and was wondering how these might look on a Gen 1.
If you're able to make them I'd love to see the pic's.
K
KNG SNKE
Post me a photo of the underside of the rear bumper on your gen 1. I just need to see the bolts. They should be able to fit the early years as well. I'm pretty sure the only big difference between gen 1 and 2 rear bumper covers are the exhaust hole. I have one guy who has a gen 1 on the list for next batch, will see if I can get him to post photos.
jdeft1
Metropolis
Here's a couple pics of mine. Looks a bit less straight-forward on a gen 1 (to my eye).
Apparently I need to get under it and do some cleaning...:smirk:
K
KNG SNKE
Actually judging by the photos your rear cover mounts on the same way as a gen 2. The only part that makes it slightly more difficult is that you don't have stripes or a rear exhaust hole to line up the fins. You will be lining them up by eye or will have to find a reference point to make them straight. It seems they are compatible though. One thing to note is the fins will have to be bolts to the outer bolts, not the 5 directly in the middle. You can try to bolt a set there but they will be further out then the rest. I am not positive how it will look.
