Gen 2 Air Conditioning parts
EGarza1971
Texas
Hello Viper Lovers,
I have a 2002 RT/10 and ac went out. I got it filled, and it went out again, so have issue with the lines. Does anyone know where I can get parts for the ac? Here are the items I need:
-5245035AB
-04848164
-5264924AB
please message me if you know. Thank you! It's hot down here in South Texas!
Aberk
GA
I think the AC is the most common reason I take my GTS to the shop. I tried doing things on my own with dye, but those guys have better machines for testing AC. Did you have a leak test performed? One time it was only an o-ring that needed to be replaced for me.
If you see them on Ebay, I have had luck with the 4 seasons brand when I did have to replace lines.
blue73Chevy
Canada
I have all those lines.
Came off a 02 rt-10.
But I'm in Canada,shipping might be an issue
600 for all 3 lines,u cover shipping.
The hard lines are well supported and are rarely the source of failure unless there is crash damage. Assuming no damage of the condenser, the #1 cause is termination o-rings, #2 are the hoses themselves. You can source refrigerant hoses and new hardline adapters from Vintage Air in San Antonio https://www.vintageair.com/hose-kits-fittings/, or through their extensive dealer network list. You can re-use the OE hard lines with either compression, 37 degree flare, or o-ring face seal adapters from Eaton/Aeroquip or Parker. A quality hot-rod or race shop can help you with this.
Jim Myke
Troy Michigan
I have a 1998 rt/10 and a few years ago I needed some ac work, many of the lines for the ac are stocked parts at your dodge dealer because they used a lot of off the shelf parts from other models, ac lines are one of them.
