STL RT/10
Believe that I lost the power steering pump while driving today. '02 RT/10 with 7k miles.Steering got heavy, so I pulled over and checked under the hood. The pump had seized and that actually was enough to stop the entire belt from turning (I thought it would have just been spnning around the steering pump pulley. Therefore, the water pump wasn't turning and it got a little hot. Fortunately, I was in a shady spot with a breeze and got it turned off immediately. The steering fluid reservoir was full and the fluid was clean. My questions...
1) Is there any way this could be an issue with the rack? I wouldn't think so since the pump stopped turning completely, but certainly don't want to work on more than I have to.
2) Anyone had similar issues? I know the caps had a habit of coming off, but I didn't know if complete failure was somewhat common, especially given the low mileage.
3) Does anyone have any experience with how long Gen 2 engines can run at elevated coolant temps before warped heads and a block become a concern? I pushed top end (250 degrees) for probably a minute or so before I got it turned off. Lost only about a cup or so of coolant out of the overflow.
4) What is the preferred replacement steering pump and where have you purchased from?
Thanks!
Matt
Thanks!
Matt
