eabrillon1978
Did some fishing this weekend and also removed the steering shaft from the car.
The factory coating didn't hold to well from the heat over the years. I wanted to freshin it up a little bit. Comes out every easily and pretty much only goes in one way as long as you don't move anything around and mark which way is up and where the upper shaft is you'll be good to go.
Here's some before and after pics
Angle of attack!! LOL
Before shots..
Used some Black VHT Caliper paint. I sandblasted the steering shaft, had to tape up the little U joints as well so I didn't get any sand on them. Came out looking great!!
After I pulled off the steering shaft, I noticed that this little seal around the steering gear was broken and brittle. I'm going to go to the parts store today and see if a dodge dakota pickup's seal is the same as the vipers, hopefully so.
Before shots..
