Gen 3&4 Battery access cover replacement from Doug Shelby Engineering
GreenVenom
Battery access cover GEN 3&4 replacement
Originally Posted by SSGNRDZ_28
DSE 03-10 SRT-10 quick release battery covers
http://dougshelbyengineering.com/Viper.html
This is what you need for your Gen 3&4!! This replaces the factory battery access cover which if you have had to remove and reinstall you know is a total PIA! From Doug Shelby (contact info above)
My cover came today and all I can say is WoW!! Great idea and a much! much! better than stock access cover. Quick install and world class engineering.
Took me 39 minutes from opening the package, cleaning out my trunk, removing the old one, installation, stuff back in the trunk and putting the tools away. This should of been what the factory installed. Thanks Doug!!
Here are some photos of the quick release panel and associated hardware.
Attached Thumbnailshttp://driveviper.com/forums/attachment.php?attachmentid=1560&d=1386164836
http://driveviper.com/forums/attachment.php?attachmentid=1561&d=1386164840
http://driveviper.com/forums/attachment.php?attachmentid=1562&d=1386164844
http://driveviper.com/forums/attachment.php?attachmentid=1563&d=1386165153
There is also an option for a bracket to hard mount a battery tender connector to the underside of the panel which can be accessed through the rear vents.
http://driveviper.com/forums/attachment.php?attachmentid=1564&d=1386165434
http://driveviper.com/forums/attachment.php?attachmentid=1565&d=1386165438
http://driveviper.com/forums/attachment.php?attachmentid=1566&d=1386165442
G
GreenVenom
Cleaned up post for easier reading
Puntacanaviper
