Hi George,
Answers below.
With this middle of the road system, specifically what power adder options do I have if I want to stay NA? I can imagine the throttle response issue could be fixed and also raise the rpm limit if the engine is built to take it.
Unfortunately, the Throttle Response issue is inherent to the Venom controller programming. In the case of what I am talking about, the throttle control would be left to the Venom Controller. The only way to circumvent this is a standalone with Drive By Wire control, or going with a mechanical throttle body arrangement, which COULD be done, but you would then be crossing right back into Standalone territory. The configuration of the Gen-4 more than the Venom Controller itself is what pigeon holes you into certain options.
Rev Limit could be raised.
The traditional SCT system with the Gen 3 allows you to do the head, cam, etc upgrade, right? For the Gen 4, if I'm understanding you correctly, the cam is a limiting issue and if it is changed, then we start getting back into the stand alone system, right?
Yes, Cam and FBW related items. Again, there are other solutions such as solid cams and Mechanical Throttles, but we are then heading right back towards Standalone territory. That being said, the FBW and Cam should not be major detractors from mid-tier builds, with the obvious exception of the throttle lag, which everyone already has... nothing new there.
I'm just trying to get clarification here, your responses are technical, but honestly crap from a marketing side when describing what your are trying to sell me, how much it is going to cost and what I can expect. I understand your point that no two horsepower outputs are going to be the same because each build and modification will yield a different outcome. But your attitude almost sounds like the Nancy Polesi argument of vote for Obama Care and then you can find out what is in the bill....not fair to us non tuners that are just trying to figure out what the hell is possible, capable and feasible with this damn Gen 4 computer and motor we are stuck with.
Trust me, I am very aware that my responses are very vague. I am doing it on purpose, as much as I do not want to be doing so. This market is littered with Copy-Cats, and I know that as soon as I even post "how" it will be done or can be done, I will have someone else trying to bring out something based on my ideas before I can even get it to market. It *****, but there are absolutely vendors in this market who steal other people ideas and work in the background, and then pass it off as their own. Multiple actually... and I have fed them enough in the past. The problem is that I don't have the resources working in the background to slam something into production on a whim. I need to schedule it and keep the current customers happy- its a balancing act. Until I expand a bit, its a continuing problem... which unfortunately the state of the market and economy, and especially this POS state of NY, aren't exactly helping. I just need to make sure that if I decide to postpone this, or go in another direction, that I didn't just hand over the keys to the kingdom to someone else.
Tangent: All that being said, what is easier to market... a 4-5K tuning option that opens up enough doors to actually do something, or a 8-10K "package" deal that both adds tuning ability [still mid tier], but also rids the FBW issue by going mechanical, and adds ~50+ horsepower w/a custom solid cam grind and pre-packaged tune? [requiring Int/Ex obviously if not already installed] This could possibly be made smog-able as well.
The G4 just presents a REALLY tough marketing area. No matter what you do, its expensive to try and solve everything- so nobody bothers.
