Gen II dash ?
diegoted
Diego-Town
What does the arrow inside the circled pod indicate? I think it's a shift arrow but it only flashes when I am in first and only part way through 1st gear?
Secondly what is the wheel for in the pic that I have circled? Dash light brightness? Sorry for the crappy pics.
thanks Diego
Snake#36
Wilm.,NC
The arrow is a shift light...you need to accelerate enough for the light to go out before shifting into 2nd gear......the wheel is the dash light brightness ....
Rickman6
Sweden
the arrow indicates the skip shift function is active you go from 1st to 4th skiping the other gears = you are driving too slow!!
second picture is the adjustment wheel for the light brightness in the instruments
Paul Hawker
San Diego, Calif, USA
When many of the Gen II's came from the factory, the owners manual was placed in the pouch behind the passenger's seat. Might be worth a look. You also might find a pencil sized metal hook, that was used to remove the center hub caps.
Yellow light was a government mandated upshift indicator, to let you know when to shift into the next higher gear for fuel economy. In the Viper this often conflicted with the also mandated 2nd-4th gear skip shift. If you shift when the yellow light first goes on, you will also trigger the annoying skip shift. Most of us just ignore the little yellow light, and wind it out just a bit to avoid the skip shift.
A really cool item, is that the little yellow light serves a dual purpose. When approaching the rev limit, it turns red, and lets you know you are close to the rev limiter, and should shift up to the next gear. First car I ever drove that had a factory stock shift light.
As far as your dash dimmer controller, if you turn it all the way down until it clicks, your interior lights will not then come on when you open your doors. Kinda stealth mode.
Nice to know if you are working on your car, or just have the door open to listen to the radio while waxing it, so your battery will not be drained by the interior lights staying on for hours.
You will also see a tiny red blinking light on the backside of your rear view mirror. This will blink fast or slow to notify you of the status of your alarm system.
Vipers are really pretty clever vehicles. Lots of extra thought went into their design.
D
diegoted
Diego-Town
Thanks Paul, I love little tidbits like that! Darth, really appreciate the link.
Diego
luc
Paso Robles CA
I don't know witch car you are talking about but i never saw a gen2 ( including my 00GTS) having either the shift light turn red or a blinking light on the backside of the rear view mirror.
bmillionaire
