GEN II modified to compete with GEN IV ACR
FastZilla
San Antonio, TX
Smokin'2 is fast. He played peek-a-boo with me in my bone stock ACR for a few laps - then he was gone (sorry Mike :lmao:) - the only reason that I could tell was because he picked up some extra weight out on the track (dirt I think):omg:
We purposely played lead follow and the conclusion from both of us was that I could not follow his line and he could not follow mine. With the 3.55 gears and extra Hp the GTS was actually faster then the bone stock ACR, especially on the straight. But the GTS could not carry near the corner speed into turn 1 or thru the carousel turn.
None the less it was very close - Mike is very fast. The ACR will make posers like me faster then we really are. The other "Houston" driver is very, very, very fast. Both him and Smokin'2 are running an extra 40+ hp over my stock ACR - this makes a HUGE difference when driving out of corners and charging down the straight. Like "Why are they running away from me? We have the same car?" Even more pronounced on tighter tracks. Lowering a stock ACR to 4.5" or even 4" will shave secondssss off your track time alone - talk about a free-be mod!
I'd be interested in Smokin'2's comparison between the GTS and the ACR - he would know. I've been so scarce last year I have not had a chance to ask.
PS: I'm still going blind :rolleyes:
FastZilla
San Antonio, TX
He was NOT easy to shake! I was the "sweating ACR driver" :omg:
Now for my excuses:
  1. Corded Tires
    Less HP
    Stock ride height
    Something in my eye
    Fat passenger
    I had to ***
    I was not staying at a Holiday Inn Express
....OK REMATCH :drive::D
Couldn't have been that good, Mike in his 97 gts with no aero was all over you. Maybe you should stick to Ducati's.
PDCjonny
This has been one of the most interesting threads in a long time and it's great to hear from some ******** racers who really put their cars to the test.
I love reading this stuff. Keep it coming.
N
NI-KA
Canton, Ohio
Yes, I agree this has been a great source of information. It has really given me the opprotunity to consider my current options and open the doors to new possibilities.
Each generation of viper has unique possibilities.
Currently for me it is similar to that commercial I see shown for "Chasing Classic Cars". The one where the host says. "You can drive the 1934 Riley Imp and have just as much fun as if you were driving the 1929 Alfa Romeo 6C Super Sport, well almost just as much fun"
That is the bottom line; Having fun ! I suspect that as long as my GTS is up and running I will be having fun.
Hope I will "catch up" to everyone at the track.
mnc2886
Houston, TX
There are alot of things that can be done but is there any hope that a modded GEN II can keep up with the GEN IV ACR?
QUOTE]
I've been where you're at. Got your PM. There is a lot of great advice already in this thread from people I would assume are more experienced than myself. I got my GTS and myself to the point where I was respectably fast and then promptly bought an ACR after getting to drive one. :2tu:
A lot of the answer depends on the type of track and habits of the driver.
It goes without saying that you should invest in the slowest thing in the car if you haven't already: the software between the seat and the steering wheel. I ran with a few ACR's at the track where the driver experience alone made up the difference.
You need an upgraded oil pan with swing arm for sure if you are taking any sweeping turns to protect the motor. Before buying my ACR I was running my GTS very regularly and pretty quickly with no problems. The mistake I made from a tracking point of view was putting the Roe on it. Plenty of guys will tell you they run a Roe with no heat problems.......sure. Not in the Texas heat and not going all out for 20 to 30 minutes.:cool: If you are just going 60% you'll be fine. If you are trying to run down the next car constantly you will get too hot in the summer.
I still have the stock suspension on mine, no aero. She became fussy as I pushed the limits to keep up. I didn't mind because the threshold is predictable and easily corrected. Your comfort level would probably be much higher changing up the suspension and then looking at the aero. Depending on the track gearing can make a huge difference. I run 3.55 gears, big brake kit, aggressive alignment, 305 and 335 18 inch kuhmos with necessary safety equipment. I had the car conservatively tuned to 550 RWHP for the track. I would think this is the RWHP you will need for a larger track if you hope to keep up. I would save any additional HP for last though!
On my home track I have run even with new ACRs with reasonably experienced drivers but one very good driver here in Houston just ran away from me....come to think of it he still does just not as quickly! I will say that 2 weekends into my ACR I was running 7 seconds faster than I ever did in my GTS at Texas World with a lot less effort. Once I drove an ACR I was hooked.
Running with an ACR with your current setup can be done at many tracks if you are a better driver. Be prepared to work on the car more than the gen 4 guys between sessions as well as between weekends if you are going to go the HP route to make up the difference in times. My 2 cents: DO NOT GO FORCED INDUCTION and concentrate on:
1)Good breaking, looks like you covered it.
2)Good rubber/wheels with decreased unsprung weight...the biggest jump in performance for me occurred with this step!
3)Suspension: A good alignment and changing your compression and rebound go a long way.
I WOULD THINK THE AVERAGE FELLA WOULD STOP HERE UNLESS YOU ARE REALLY ********.
4)Think aero at this point if you are really still needing a bump up in performance. You may find if you get more seat time that the average ACR is running the same lap times as you.
5)Get some more ponies NA if you are trying to keep up with experienced driver's in their ACRs.
If you want nitty gritty details just ask. Most of what I did was following the advice of Jon and Russ at Archer. They never steered me wrong. Good luck. Trust me, the only thing better that making an ACR driver sweat by keeping up with them in a gen 2 is passing them!:2tu: Granted, that only happens with a significant experience difference. The weight and aero work wonders in the ACR.
I have been debating over which Viper to get to meet my wants for the last 3 months. I've gone from gen II, to gen III, to gen IV and back the other way while mixing it all up. This last week I've been thinking that an ACR would satisfy my wants better than any other Viper, but was never sure I would feel necessary to pay $10K more for an ACR. The looks just about had me set on an ACR, and this post got me hook line and sinker. Maybe you should be put in charge of selling the remaining new Vipers so Dodge can reveal the new viper without sales losses. I hate the waiting game. My Viper savings account is open and filling up, but I still have to wait until next year. The waiting is killing me.:aargh:
Dan Cragin
LA, CA
I have prepared every year model for the track. Each generation Viper gets better in numerous ways, but any Viper no matter what year can be a good track car.
Enjoy what you have and keep it well sorted, there are many options and upgrades but the key is a balance to make it all work right.
feel free to call for advice.
FastZilla
San Antonio, TX
mnc,
First time you turn off the straight onto turn 1 or take a carousel in an ACR the aero will make since. Best upgrades for the money in an ACR (IMO): harnesses, Mintex (anything better than stock) brake pads, SS brake lines w/good (RBF-600) brake fluid, lowering the car & setting the compression & rebound from full soft (factory) to in the middle (7&9 is a good place to start). Will cost you in the $1200-$1400 range for all.
Do the SS lines, pads, fluid, C&R adjustments & harnesses yourself - it will help you on the track to know how to do this anyhow.
Not starting an "oil" thread but 15-50 is recommended in hot climates & track use. (So I read on the internet ;) )
DaveGF
DaveGF, did you post your mods ? if not, would you mind and the weight of the car.
The engine is N/A and close to 800 HP at the crank. Top feed injectors, individual coil pack at each cylinder and MoTeC engine management. Stryker heads, forged bottom end, dry sump, Tilton clutch. EMCO sequential box integrated with the MoTeC for no lift, no clutch upshifts. Big front splitter, rear wing and rear diffuser. Flat bottom. Penske 3-way adj shocks w/ EMI Racing suspension mods. 345 Hoosier R100s rear and 315 R100s front. Fiberglass hood and doors. Windshield and back glass are Lexan. Brembo brakes with Snake brake ABS. 2,900 pounds, wet except for fuel, no (fat) driver. Jeez - seems like I ought to be faster!
shooter_t1
Has Left the Room!
Texas
I didn't realize just how bad *** your car is:2tu:
treesnake
St.L
Hey Bill. That was me. You are correct on the time difference - more like 1/3 sec, not one to two (the memory is the second thing to go!). Ben actually did 23 laps, not 5. The five laps entry is how far behind he was due to him having a tire blow with five laps to go. The relatively small margin of victory (12 seconds, not 5), was due to a caution somewhat over halfway throughout the race. I was leading by Ben by about 25 seconds at the time of the caution - despite having started last due to our mechanical problems Saturday. Totally different cars though. I think Ben is a faster driver than me, we will see in the Viper Cup this year.
The Gen II is sorted a bit better now. At Hallett a month after TWS, it was just over 1 second faster than the fastest ACR-X.
To be clear, I love the ACR-X and look forward to participating in the Viper Cup this year. The Gen II is just a labor of love for a really cool track car that is only justified on that basis, not economics and not as a car with a large class of competitors like the X.
I think the X could surpass My Gen II with some fairly inexpensive mods targeting weight (no lead added as Viper Cup cars have) and lexan instead of glass. Throw in gearing changes and I think it would be right there.
Dave
Hey Dave
I was at Viper Days at Hallett. I was one of the guys that kept coming over to your pit area and drooling....;)
DAVE"S GEN 2 SMOKED any vehicle that was on the track with him.
It is an awesome vehicle. The car looks good and performs even better.
I got some pretty good photos. Think I did a walkaround video too.
I'll send it to you. Post if you want to.
DaveGF
DaveGF,
Which differential and ratio?
Stock ratio Quaiffe but the EMCO transmission is custom close ratio - about 175 MPH redline in sixth. Will require re-gearing for a place like Daytona.
DrumrBoy
GA
DaveGF, how do you like the EMCO sequential? (I assume its a dog-ring type set up rather than the conventional synchros). You're running a sh*tload of HP and TQ so if it can handle your TQ, then I'd be fine. I'm really sick of grenading Gen 2 and Gen 3 trans' on the track, and am willing to try something that's going to handle my meager 585 RWTQ all season long on road courses.
From your experience with them are you a supporter or would you go a different route knowing what you know now?
REDSLED
Bakersfield, CA USA
Drumr, why do blow those trans's ? ever try the gen4 ?
Yes, why are you blowing the trans? I'm running 550 RWHP and have had good succes wit the stock transmission. Are you losing 5th gear? That seems to be the weak spot if you have touched the ratios in the differential as extended runs on straightaways in 5th gear does tend to cause that cluster to grenade.
DrumrBoy
GA
Plum and Red, not sure why it happens, I generally lose 5th....sometimes after only 5-10 hours (hard hours mind you, but that's not alot of time).....and thenn a few others go away too. I haven't tried an Gen 4 though I recently blew up a well-built Gen 3..........I wasn't even shifting at the time. I went into 5th on a long straight......stayed on the throttle for 2-3 seconds and boom.
There's one turn on one track where I don't match revs....have to go from 5th to 3rd, 155 to 60 very fast....was thinking this might have strained 4th and 3rd....but its generally 5th that lets go.
Any thoughts are welcome. Going to try a G-Force next....ut maybe ought to go straight to EMCO or another brand of dog-ring sequential.
DaveGF
I love the EMCO so far. I had a stocker but blew the input gears out of it.
99 R/T 10
Enterprise, AL USA
This is probably a similar situation that the guy s that run the mile event run into. Under heavy acceleration, the oil will tend to drift to the back of the transmission and the lubrication needed goes away. I think a few people have had external pumps installed to augment the lubrication and keep the trans from blowing. There is more info on the modification over at Viperalley. :2tu:
Boxer12
Colorado High Country
Build the car on the right, and it will compete very favorably with the cars on the left... ;)
I am sure the GTS-R has run at VIR, any of the historians here have a time?
DrumrBoy
GA
Good idea, I didn't consider that. I have a trans cooler and pump, I'll have to check where the pickup and input are....ideally the pickup is at the back and the input at the front but maybe they're both in the back.
Dan Cragin
LA, CA
5th gear failure is a common issue for cars that run at high speeds, primarily on the track. A transmission cooler is the best way to improve lubrication to the 5th and 6th gear sets. These gears are the furthest from the lubricant and are prone to heat failure under hard use and high G-loads (which pulls the lubricant away from the gears). When we have a transmission setup for a cooler we have the oil return path go onto these gears.
For a streetcar that competes in high-speed events (like the mile or Silverstate) the complexity of a cooler and pump may not be needed. If you make big power, you may want to upgrade your transmission for higher loads as well as heat. First off, there are numerous updates to the original T-56. If you make big power then the later Gen 3 or 4 transmissions are the choice, the SRT Ram transmission is the most durable. Better syncros, shift forks and shift pads are common upgrades. Gear ratio changes to fifth and six gear are common- this lets you use 6th gear for top speed and makes the rpm drop in the upper gears much closer. One thing that will extend the gear life (5th and 6th primarily) is to have all the internal parts micronite finished. This is a chemical coating that will reduce heat in the transmission dramatically.
DC Performance and other vendors can provide transmission upgrade services. For transmission related issues or questions, feel free to call us.
Hope this helps.
Dan Cragin
LA, CA
No it is not. These transmissions need to be modified to accept a speed sensor.
shooter_t1
Has Left the Room!
Texas
Hope this helps.
Dan, I plan on running a "Silverstate classic" style race here in Tx. I have an 09 Aero Coupe. Will I need to upgrade the transmission?. Probably be around 600 rwhp when I run.
Chuck 98 RT/10
tampa, fl USA
Is there a kit for the DIY'ers?
