When are you planning to go pick it up?
Well, the numbers are in!
This car just put down to the wheels: 613.5 HP, 589 Ft/Lbs. Peak Power was made at 5950 RPM, and Peak Torque at 5100 RPM.
As noted earlier in the thread, this was built with zero-compromise on the low-end and driveability, that was a primary stipulation. Boy... did it deliver. The car sounds incredible, drives as well as stock, makes just shy of 500 Ft/Lbs at 1500 RPM, still cranks out a hair over 700 crank horsepower... and I dont have to tell anyone how good it looks.
Personally, I think this car is just about at the limit of NA horsepower before you start to give up something somewhere else.
Overall, I think my final conclusion is that there may be a card game, or a fight to the death over whether or not Tom gets this car back. I want to keep this one.![]()
Well, the numbers are in!This car just put down to the wheels: 613.5 HP, 589 Ft/Lbs. Peak Power was made at 5950 RPM, and Peak Torque at 5100 RPM. As noted earlier in the thread, this was built with zero-compromise on the low-end and driveability, that was a primary stipulation. Boy... did it deliver. The car sounds incredible, drives as well as stock, makes just shy of 500 Ft/Lbs at 1500 RPM, still cranks out a hair over 700 crank horsepower... and I dont have to tell anyone how good it looks. Personally, I think this car is just about at the limit of NA horsepower before you start to give up something somewhere else.Overall, I think my final conclusion is that there may be a card game, or a fight to the death over whether or not Tom gets this car back. I want to keep this one.![]()
