lawdogg149
- Joined
- Jul 11, 2014
- Posts
- 35
- Reaction score
- 0
After running my car pretty hard a couple of weeks back at road Atlanta I had a few issues. First off after the second session I saw oil leaking from the rear of my air cleaner box. After talking with the other two guys there with gen v's they had the same issue just not as much as mine. Ran a couple more sessions and a check engine light and reduced power mode came on. This was pretty scary since it occurred in turn 1 at 100 or so mph. I lost steering and braking for a brief second till the rpms died to 2000 rpm. I limped around the track into the pits. The code showed MAP sensor correlation. Good friend Royce helped me erase the code and back out I went. The more I ran the more oil came from the rear of the air cleaner box onto my engine. I finally decided it was to much to keep trying and just drove the car home. Took the car to the dealer yesterday they cleaned the oil off and ordered a new air filter in which was covered in oil. Just wondering if anyone else is seeing this issue. I know performance cars do blow back oil but over 1/4 of a quart into my air box and all over my engine is just to much. Talked with mark at woodhouse he stated there wasn't a Gen V designed can. Seems that if this is a real issue then the factory should of put one on from there. Bad design or does my car have just a bad pvc system?
