goldcup
I definately will be there!
Personnaly, I use Meguires straight in the container, add a little water to allow it to **** up into the gun faster and go to town. It uses a lot, but that isn't the point. Getting a thick foam is the point. I've tried it straight and with more dilution, but I've found a good mix that will work until I finish off the the gallon jug. What I have left in the container goes into my wash bucket to be used with the mitt after the foam has done it's work.
I'm going to try Adam's soap as soon as I finish this off and see how it works. Washing the Viper is relaxing for me, so I do it quite often. In fact, it's getting a wash tomorrow due to getting splattered last weekend. As I've stated before for you garage queen types, check out Adams's Waterless Wash. I tried it last weekend and liked the results. Haven't heard from AJ yet though ... what do YOU think Junkman? I've SEEN the video, but I want to know if you REALLY use it on your Vette.
It's all good bros.....
Junkman - Don't make me ride down from Long Island to Doylestown with my gear...LOL![]()
Just used my Gilmour with Meguires the way Junkman uses his, 3/4 full of water and 2 oz of soap (Patron tequila size ounce), once I got the setting right, she covered my DD (300C) like a heavy snowfall. And once I got the setting right, it sucked up that liquid fast. Used the whole gallon. Next wash will try it the other way.
You got a gallon foam gun?![]()
Reading the above replies, it looks like they say don't leave the soap in the gun. It will gum up and clog.Now the only question is can I leave the soap in the foam gun until I use it again or will that mess up the foam gun?
I got the foam gun a few months back and was very disappointed with the results by following the 3/4 water and 1/4 soap. Sorry Junkman, your foam gun or soap must be different because I went with only soap yesterday and it worked great. The information I have gotten from you has been priceless and my Viper thanks you.
Now the only question is can I leave the soap in the foam gun until I use it again or will that mess up the foam gun?![]()
I just open the shampoo bottle up and dump it on the car--leave it on the car overnight--then drive it fast the next morning--Dave
..... a new washing machine and it requires a special soap that has low suds. It works great, better than anything else I've had before.......
soaps have different sudsing formulas depending on how the intended washed item is to be rinsed - once, twice, alot of water, little water - old machines used a lot of water so the suds would be diluted and go down the drain, not so with the new water efficient machined. this is why dish washing liquid suds a lot, but dishwasher soap does not.
The key to the suds is that they contain enough soap to break up the matted on dirt but also enough water to help the suds work.
