I was installing a set of motor mounts on Gene's 2006 SRT10 Viper.
It appeared to be a straight forward install but ended up not being it.
I think it might be due to getting a duplicate set of mounts for the same
side (Driver's side). If you look at the illustration I made it will explain
the situation. I finally got the motor mounts in and everything seems to be
fine and aligned right, but it appears these mounts are either #1 not
really made for the viper, but can be used if modified. #2 I got two
driver side mounts by mistake when they were order.
The passenger side mount would not align up right due to the round
raised nub on the back side of the mount facing the frame.
The round nub was preventing the mount to seat properly against the frame.
Further investigation showed that the OEM did not have this round nub
on the passenger side mount facing the frame. See the illustration.
So I had to ground down the nub on the passenger side facing
the frame side and everything aligned up correctly afterwards.
Any thoughts? (All is fine by the way after I modified the mount).
