V10 ACR
No work today so I worked on the viper. I was recently at VOI9 and with all the driving and the temps in Vegas, I was hot too much of the time. I saw DC performances vents at the vendor show, but the viper tax was too high. I got some premium stainless steel mesh and cut out a portion of the resin side piece. Took all of 40 min per side including removing the side sills. Not the cleanest job, but I think it looks good and will help keep temps down. The side sill insulation is in tough shape with the metal portion by the cats has vaporized. I may need to replace it soon.
New vents
I also had a front vent kit from Roe that I had been meaning to install for quite some time and I finaly got around to all the cutting and riviting. Once I started the install it became very clear why this can lower the temps. There should be a ton more air flowing through the various radiators.
It looks reasonably clean from underneath.
You can hardly tell from the front, even at a low angle.
Can't wait for more track time!
New vents
