Harbor Freight aluminum jack $89.99
1TONY1
Dalton Ga. (Chatt. Tn.)
This is a little different than the aluminum Harbor Freight jack that I have now. Both are made by U.S. General. For $95 shipped I am going to try it and replace the heavy jack in my trailer. I have been very happy with my current jack....it gets a lot more than occasional use. Specs on both are below.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91039
$89.99 Jack:
High performance aluminum racing jack lifts 3000 lbs. to a maximum height of 15-1/8''. Requires only 1/2 turn to release. Constructed for professional racing teams out of precision-machined, high strength, aircraft aluminum billet. Specially designed 4-5/8'' wide, low profile, single front roller wheel for quick and accurate placement where you need it. Low profile 3'' minimum saddle height comes with 360° rotating rubber pad to prevent marring
Minimum saddle height: 3''
Maximum saddle height: 15-1/8''
Handle overall length: 23''
Two piece knurled aluminum handle prevents slipping
Overall dimensions: 20-1/2" L x 9-3/8" W x 8" H
ITEM 91039-1VGA
$139.99 jack I think this is the one I have now.
Rapid Pump™ high performance aluminum racing jack lifts 3000 lbs. to a maximum height of 17.5'' in only 6 pumps and requires only 1/2 turn to release for lightning fast pit stops.
Specially designed 5-3/8'' wide, low profile, single front roller wheel for quick and accurate placement where you need it. Low profile 3.5'' minimum saddle height comes with 360° rotating rubber pad to prevent marring.
Minimum saddle height: 3-1/2''
Maximum saddle height: 17-1/2''
Hydraulic lift: 14''
Handle overall length: 47-1/4''
Overall dimensions: 23.62'' L x 11.81''W x 6.1''H
Tool weight: 35.40 lbs.
Rick J
Are these jacks able to go under the side sills to lift the front, WITHOUT running the car up on wood? Thanks for the info!!!
ViperRay
Topeka, KS
I have 2 jacks (neither of these). One of mine is a "rapid pump" and the other is not. There is a big difference in the total effort expended lifting the car to the desired height between these 2 jacks...I would not get the slower pumping jack again for the difference in price mentioned above assuming this relationship also applies to the jacks you mention. Just my $.02.
Jack B
NE Ohio
Tony:
with a handle length of 24", it has to be limited in either rise speed or by the amount (large) of force required. I have the same jack that you have and it is a great deal and has remarkable workmanship for $150. However, if you compare it to a full range/weight jack, it is still slow and requires far more force to get lift. Let us know how it works.
bmillionaire
