Help Needed on 93
Fort Lauderdale, Florida.
Dr Robert Harms -
I read your punch list and think I'm pretty confident to answer your questions. You've got a large list to go over so if you wouldn't mind contacting me at your convenience I'd like to offer some help.
Regards,
Doug Levin
FRANK
Somewhere in southern NJ
Sounds to me that you are trying to fill the tank with the car running...are you? The other problems are all small ones. Take a deep breath. Don't forget your car is 8 years old. **** is going to happen...
David Jenkins
South Orange County, CA.USA
1. poss. fuel pump. easy test- turn ignition key on and off 3-4 times. leave the key in the run position for at least 3 seconds each time you cycle it. listen for the fuel pump to cycle. then try sarting the car normally.
2.check the speed sensor wiring to see if it's split over top of trans case. several cars have had wires cut from laying on trans. shouldn't have taken 30k to rub through???
3. poss vent valve. takin' the tank out anyway for pump??
4. just gotta' muscle it out. spray a little lube down in it. lightly lube the lock plates before you reinstall the windows.
a bit of lube on the thumb screw also makes it go in a bunch easier.dj
Vip-RT10
Clearwater,FL.USA
I have a 93...If you would like, Chuck 98 and myself will go look at your car, we live in Tampa and New Port Richey...I'd be glad to help a fellow 93. Write back if you want us to help you...
Doc....... That Snake is just gettin out of HARMS way !
Doug, Antonio et al are great VCA supporters and can troubleshoot ya fine. Dave's advice is spot on.
Great Club, Eh? Hope you are a dues-paid MEMBER, singing Willie Nelson in short order.....
"on the ROAD AGAIN.........!"
ViperGear
