Matt-
A few things to keep in mind.
I agree with most of the things already mentioned, so it is not necessary for me to repeat, but:
1) I am not sure of the emissions and laws in MO. DO you have to get it checked every couple/few years? Are they strict? If so, then you need to make sure the cam you choose will pass the test.
2) Definitely do heads and rockers with the cam since the engine must be dis-assembled anyway. By that time, your primary costs are for parts. If you do the cam, I would only use the T&D Rockers as opposed to others.
3) Can't say for sure, but I believe most of the power numbers quoted above are for a GENII. Your numbers will, most likely, vary for a GEN I motor.
4) If you have your heart set on doing a cam, make sure the valvetrain and heads are up to the task. Since most aftermarket cams have more lift, stock valves and Mopar valves won't work.
5) With all of this work, you will probably require custom computer tuning on the dyno for ultimate driveability, power, and longevity.
We do offer sniffer legal cams, and are heads are built to handle aftermarket cams. We will also offer custom computer tuning on our in-house dyno.
Good luck!
-Wayne (LTHL VPR)
