HELP!!!!!! Speedo not working......
Neil - UK
ENGLAND
whats happin' Doctor Bob... something viper you cant fix :eek: !! you must be loosing it :crazy: try *** she will know the answer
Good luck with the test, let me know how it go's :headbang:
Neil - UK
ENGLAND
aaah he did... as the US spec radio wouldnt pick up his favourite UK country music stations :D
GoCanes1
Nashville, TN
This happened to me. Dodge has the stock radio connected to the speedo to increase volume when the speed increases because of the noise. If you pull out the speedo it is connected to a wire that leads to the radio and to a wire that leads to the PCM. Disconnect the radio wire and everything should work. Unless the speedo shorted out like mine did, then you need another.
Hope this helps.
VIPER BAZ UK
ENGLAND
Stock radio fitted an now all OK ..
MANY THANKS :2tu: :2tu: :2tu: .......
Baz
Ps is it a dash out to get to this wire???
VIPER BAZ UK
ENGLAND
Dont suppose you know the colour or pin No Of the wire that needs cutting at the speedo plug??
Baz
