Help! Viper Wont Start...
rtalex
Hi All, my 2005 Viper will not start. Had no issues previous to this. Basically, when i press the push start nothing happens. The battery is fine. The starter is fine. Full Gas Tank. The car is recognizing that the clutch is pressed all the way down. It appears that something like the factory alarm is causing it to not start. I have checked all fuses and relays. Everything appears fine. Is there some way to reset the factory alarm? I may be completely wrong, but that is the only thing i can think of. Any help or suggestions would be greatly appreciated!
USMCLY
pull battery and step on brakes and let it sit a bit and reconnect battery and try if that works
tbsviper
I know you said it but be sure clutch is fully depressed. Only time I experienced what you describe.
tanikinsap2
