Help with Valentine 1
HLN A55
Austin, TX
No matter where I place the V1, I am picking up some stray K-band that sets of the detector constantly. I have an aftermarket alarm, and an amp in the trunk-is either one of these causing it or is it a part of the car? Any help is appreciated.
"...I have an aftermarket alarm, and an amp in the trunk..."
I will bet that the alarm or the amp (assuming that you mean an aftermarket amp) is causing the problem. Are they both grounded well (say, directly to the battery) ???
I forgot to ask the age of your detector....one or two of my older (original) models of Valentine One will indeed pick up stray K band readings from grocery/drug store door openers...noting that none of my later Valentines do this.
Randy
Earth?
If the "stray" signal really is on K-band, you actually *want* the radar detector to pick it up. The fact that some motion sensors (be it store security motion sensors or grocery store door openers, etc) actually are on the exact same frequency as police radar makes it difficult for a radar detector to tell the difference.
I assume you know about the two city modes - press in and hold the volume control puts it in the first city mode (display changes from the capital A to something like an L with the upper half missing; the bottom segment and the left lower segment are lit) which will try to figure out which alerts are a threat, and only sound a full-volume audible alert if it thinks any are real (and otherwise sounds only a muted audible alert but still show the count and strength of radar sources its picking up), or press it and hold it again to get to the second city mode (which is the upper case L), which will only alert and show visible indications for only those it thinks are real. I don't recall if the city modes operate only on the X-band or both X and K-band signals.
I've got a 1995 Valentine-1 and a year 2000 Valentine-1. They BOTH will pick up supermarket door openers and RF-based motion sensors, AS THEY SHOULD - as all door openers and RF-based motion sensors operate on the same frequencies as police radar ("field disturbance sensors", on 10.525 GHz for X-band, 24.150 GHz for K-band, 33.4 - 36.0 GHz range for Ka-band); most door openers and RF-based motion sensors are on X-band (cheaper), but I've also found some security system motion sensors on K-band (at a high-end stereo shop). If your Valentine-1 does *not* pick up door openers or such internal RF-based (not IR-based) motion sensors, then there is something wrong.
One alternative you may have is to disable reception of any band you know is not used by police radar. I know for a fact/experience that there are no police departments in my area using X-band at all, so I've programmed my year 2000 V-1 to ignore X-band (the method to do so is on their web site). I'd do it for the 1995 vintage detector, but it doesn't support the programming. I use the 1995 one in my Durango, so I have a double-check to see if any local departments have gotten cheap and started using X-band again. You're mileage may vary on that one (as it is a significant risk to disable a band).
H
HLN A55
Austin, TX
Yup, I know about the automatic doors and such-and it is not what sets it off. As far as the band, I am pretty sure that it is K-but will double-check tonight.
The weird part is that the detector doen't do it in any of my other cars-all of which have aftermarket amps and alarms. The detector is about a year old. I was just wondering if anybody else noticed this problem-and that it is just a Viper "quirk" or if it is somthing with the amp or alarm.
I have NO such problem when switching 4 different Valentines among our 6 Vipers...would NOT call it a "Viper quirk" at this point !!!
Good luck trouble shooting your situation...and let us know what you find.
Luigi93
