Hennessey Headers
Viperoctane
Need help here please, I have hennessey headers that I am gonna install soon. The headers came in a box with two big gaskets, is that all I need or do I need 8 more smaller gaskets? I hope somebody understands what I am saying. Each header consists or two pieces, I can pull them out is that normal? Anyway help would be appreciated. I ll post before and after dyno slips hopefully. Thanks
pauls
Akron, Oh USA
Only gaskets you need are from block to header flange. use Hi temp sealer on collector. That is the only other connection that isn't a slip fit.
Great Falls, Montana USA
You can use the stock one piece MoPar 04848339 gasket for each side of the manifold to head (2 required) and FEL-PRO # 2001 collector gaskets for the collector boxes. This gasket kit contains 2 gaskets.
Intouch
